I have a 2001 Mustang Bullitt manual transmission. When I use the clutch and the brake pedal fuse 33 will blow. I can see the dome light in the car dim and the brake lights dim when I press the pedals. I have replaced the Muti switch based on Ford diagnosis, did not help. Replaced the brake switch and the brake position switch. I have disconnected all of the four? switch locations attached to the clutch and brake. I have checked all ground location and nothing seems to fix the problem. Should I consider running a new fused wire from the break pedal switch to the lights? Help at this time would be welcome.
thanks
thanks
