  • 1994 - 1995 Specific Tech
fuse box layout
  • Thread starter Thread starter black1995gt
  • Start date Start date Sep 10, 2008
black1995gt
Waterbury,CT
Sep 10, 2008
  • Sep 10, 2008
hello ive got a 95 gt does anyone know what number the fan fuse is in the under hood fuse box????
Stanger007
2,015
Baton Rouge, LA
Sep 10, 2008
  • Sep 10, 2008
Try this: Image:Mustang9495UnderhoodFuses.gif - Mustang-Tech
Wes
black1995gt
Waterbury,CT
Sep 10, 2008
  • Sep 10, 2008
thanks man, it wasn't the fuse.....wasn't there a recall for the fan on 94-95 mustangs cause they could seize up?
Stanger007
2,015
Baton Rouge, LA
Sep 10, 2008
  • Sep 10, 2008
JT (hissin50) wrote a masterpiece on troubleshooting the CCRM and cooling fans, it will help you find the problem...
94-95 Mustangs Electrical CCRM - Mustang-Tech
94-95 Mustangs Cooling System Diagnostics - Mustang-Tech
Wes
black1995gt
Waterbury,CT
Sep 10, 2008
  • Sep 10, 2008
thanks what is the EDF fuse and where is it found
Stanger007
2,015
Baton Rouge, LA
Sep 10, 2008
  • Sep 10, 2008
I sent ole' JT an email, he is the man at CCRM/Cooling Fan diagnostics.
Wes
black1995gt
Waterbury,CT
Sep 10, 2008
  • Sep 10, 2008
thanks man
HISSIN50
34
129
Sep 10, 2008
  • Sep 10, 2008
I don't think you guys are talkin about me because I haven't done anything helpful in some time.
Check out the very last fuse listed in Wes' very helpful diagram. Physically, it's in the bottom left corner of the fusebox in that diagram.
FWIW, EDF = Electro Drive Fan.
If you post up what your fan is or isn't doing, we can try to help out.
Good luck.
black1995gt
Waterbury,CT
Sep 10, 2008
  • Sep 10, 2008
here is the deal with the fan its not coming on at all even when i turn the ac on i checked the fuse in the fuse box that was ok i bought a new one and tried it the fan still moves if u move it with ur hand its not seized up or anything so im thinking it might be the relay thats in the fender thats bad
HISSIN50
34
129
Sep 10, 2008
#10
  • Sep 10, 2008
  • #10
The relay isn't in the fender - it's in the CCRM. Wes has a picture of it on the link he posted earlier. If you find the black bracket that holds the overflow bottle, you'll see the CCRM with all its wires [on the same bracket].
Run the diagnostic in that link (the bold part labeled Fan relay diagnostics (EDF and HEDF): - it will only take you a few mins. That way we know if the issue is on the control or load side of the circuit.
Does the fan come on naturally without the AC being on (at 208 or greater temps)?
Does your AC work? In other words, does the clutch engage on the AC compressor?
Even if the driver for high-speed fails, you normally still have function of low speed naturally and often while the AC is on.
If you unplug the ECT, does the fan come on low speed?
Is the 60 amp fan fuse in the underhood fusebox intact?
desertcox05
379
south atlanta
Sep 11, 2008
#11
  • Sep 11, 2008
  • #11
When you pull codes by paper clip method (koeo) the first that happens when you turn the key is the fan cycles on for couple secs on low then on high for a couple secs then off. that should test you relays and fan operation. I'm not saying the fan will seize up after it's been running a while. just a way to test it
HISSIN50
34
129
Sep 11, 2008
#12
  • Sep 11, 2008
  • #12
DC, I also like to do that test. It can be misleading though. I've seen the test pass (both speeds) just fine but the HEDF driver fails when commanded during operation. The result can be a passing "test" but no HEDF when the AC is on, for instance.
It is a great test though because if it fails, you know there are big and easy issues to solve first.
black1995gt
Waterbury,CT
Sep 11, 2008
#13
  • Sep 11, 2008
  • #13
the fan used to come on.....ya my ac works its nice and cold....ya theres a fuse i bought a new one and it didnt do anything...im gonna run the test tommrow and see what happens
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
F
Electrical Engine compartment fuse box
  • faredce
  • Oct 6, 2024
1994 - 1995 Specific Tech Oct 6, 2024
faredce
F
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
