Fuse for the Fuel Pump??????
There is a fusible link off the starter solenoid which is the high amp feed. the inertia switch is on the positive relay coil feed. puter sends ground and there is the pump output.
if you dont have one wire with constant 12 volts at the relay socket, check the fusible link or the wire from the solenoid to the relay for an open.
good luck.
