Fuse keeps blowing!
Danny-Boi
97
The fuse that is for the turn signals/back up lights/low fluids sensor keeps on blowing. I believe it is fuse number 5 but i am not sure and its a 15 amp fuse. I tried disconnecting the low fluids module and it still blew so i am pretty sure that it isnt that. Has anyone else had this problem?
you are on the right track. keep disconnecting stuff on that circuit till you can keep the fuse from blowing. then trace the wires. i think someone has had trouble with the back up light circuit blowing fuses before, but there is probably an equal chance of it being anything (although maybe more likely since the wires run a good length).
good luck.
