Fuse question
Fuse 13 is the dimmer fuse. The fuse is after the dimmer, so you can tap right into the fuse with a fuse tap. You can also tap into the circuit behind the fuse box or any place that has dimmed lighting (HVAC controls, etc).
Key-on power is something that can be grabbed whereever is convenient with regard to your mounting location.
Good luck.
