FUSE QUESTION
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Feb 9, 2008
mustangfan1990
505
Lenoir, North Carolina
Feb 9, 2008
  • Feb 9, 2008
Ok I got the fuel pressure and boost gauge most of the way hooked up. I have a little problem though. Does anyone know which fuse I can run the pos wire so that the fuel and boost pressure gauges come on when I turn my headlight switch on???
Fett
766
  • Feb 9, 2008
http://www.veryuseful.com/mustang/tech/engine/images/MustangLights-Horn.gif
By the looks of it, you should be able to jump off the brown 16 ga wire coming from the headlight switch. That is the lead that should get hot when your parking lights/dash lights come on. Be sure to ground the gauges well, and everything should be fine.
HISSIN50
34
129
Feb 10, 2008
  • Feb 10, 2008
Or use Fuse 13 if you want the gauges to dim with the dimmer.
Chris is right on about the brown wire. That's the parking light feed.
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • dan50
  • Jul 18, 2026
dan50
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
