fuse question
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Feb 19, 2008
mustangfan1990
505
Lenoir, North Carolina
Feb 19, 2008
  • Feb 19, 2008
on a 1990 ford mustang GT 5.0. which fuse is the cigar lighter? I have to run a wire from my Vortech t-rex pump to the cigar lighter and I dont know which one that is. Vortech recommends to use the cigar lighter. I wonder why this is?
HISSIN50
34
129
Feb 20, 2008
  • Feb 20, 2008
See here.
Fuse 16 might be what you're after. I'd imagine that the circuit you choose should only be hot with the key on. Be sure to check that.
Good luck.
mustangfan1990
505
Feb 20, 2008
  • Feb 20, 2008
HISSIN50 said:
See here.
Good luck.
Yeah I was wondering if it was hot or not but that is what the instruction manual that came with the Vortech said to hook it up. It said "hook to ciagr lighter fused side at fuse box is the perferred location" would the fused side still be number 16?
HISSIN50
34
129
Feb 20, 2008
  • Feb 20, 2008
The find the fused side: Pull the fuse and put a test light on each terminal where the fuse plugs in. One terminal will show 12 volts and one will not. The side not showing 12 volts is the fused side (it is protected by the fuse).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 20, 2008
  • Feb 20, 2008
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
  • brandyn200
  • Jun 20, 2026
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
