fusible link burning up while converting to mass air no start need help badly u know?
86 mustang gt 5.0 gt 40 heads cobra intake bbk exaust upgrade to mass air
WIRING WIRING WIRING i have two wiring questions...okay i get fuel pressure and spark but when i try to start it after using for racings maf converion harness the big green fusible link wire gets extremely hot and melts even with just straight wire (no link) and wont start i followed ford racings instructions to a t...the only thing preventing it from starting is the wire burns up or gets like red hot..the other wire in quesion comes out of the wire loom located just under the coil..well there are two wires one all black and the other black the a light green or yellow stripe (pretty sure it's light green i have both of them grounded right now and begining to wonder if they're suppose to be power wires and to be hooked up to the positive post of the starter fenderwall solonoid...i have three fusible links hooked up to it two that came with the harness one brown one blue and the big green one...withought the green on hooked up i get NO POWER TO ANYTHING............PLEASE HELP YOU GUYS ARE BRILLIANT WITH THIS STUFF
Electrical problems are difficult to troubleshoot over the Internet. The lack of punctuation and capitalization makes your post even more difficult to understand. There are only about 4 guys on Stangnet who will even attempt to troubleshoot an electrical/computer problem. All of them will tell you the same thing: translating a poorly written post into understandable English leads to confusion and frustration. If we can't understand what you are saying, we can't help you fix it.
Are you using a completely different Mass Air harness or simply one of the kits that supplies the MAF connector, wiring and pins?
Can you read electrical diagrams and do you have access to a good working Multimeter or DVM? You will need both.
Edit your post so that is is readable without having to translate it and I will try to help you.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
