Future System
Wat do you guys think about it?
Deck:
JVC Kd-HDR1
http://www.crutchfield.com/S-e3v6O2DsaC3/cgi-bin/prodview.asp?i=257KDHDR1&s=0&cc=01
199.99
Accessory:
JVC KS-U58 Input Adapter to Stereo Mini Plug
http://www.crutchfield.com/S-e3v6O2DsaC3/cgi-bin/prodview.asp?i=257KSU58&s=0&cc=01
39.99
Sub:
1 12" Kicker CVR12
http://www.circuitcity.com/ssm/Kick...17481/catOid/-13093/rpem/ccd/productDetail.do
149.99
6x9s
I have 2 200 watt each 4 way pioneers, you guys think I should replace those and put old ones in the front like under the dash or in door panels?
Amp
Help me with that one, I currently have a 400w firestorm dunno how good or bad it is, the previous owner had it.
ill post some pics of my setup when i get a chance... if you are going to mount the sub behind the seat, 12" is a little too big. i used 2 10's in a box that fits behind the rear seat, and fires forward. for a 10" sub, in a sealed enclosure, you want between .75, and 1 cubic foot of volume. my box is roughly 1.8 cu/ft for 2 10's and really doesnt crowd the trunk too much. i mounted the amps on the back of the box (one pushes my subs, and the 6x9's on the package tray, and the other drives the 5 1/2 in the kick panels) as per your other post, dont drop the head liner!!! when you remove the kick panels, you will see where the factory run the wiring to the rear of the car... unless you have a big bundle of wiring, you can pull yours just like they did in dearborn...
