Gangster lean...
  • Thread starter Thread starter casper98gt
  • Start date Start date Oct 9, 2007
C
casper98gt
66
NH
Oct 9, 2007
  • Oct 9, 2007
Im sick of it. I want to sit straight up and look normal. Is it common for these fox seats to have a lean to the right side of the drivers seat. I want to sit straight and it keeps sucking me to the right side. I took out the seat and couldnt find any problems.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 9, 2007
  • Oct 9, 2007
yes it is VERY common and it is easily fixed. just go to the parts store and get a big nut or a bunch off washers and stack them under the right side off the seat legs until you get the desired height. the nut can serve the same purpose. and if you run out of threads on your bolt get one to match it out off a bolt bin at lowes or somewhere that has the same thread pattern and use it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 9, 2007
  • Oct 9, 2007
The seat problems come in two categories:
1.) The floor pan that holds the front seat mounts cracks and allows the stud that secures the seat to pull out. I recommend that you take two L shaped pieces of 16 gauge steel and overlap the damage. Cut and fit one "L", drill the bolt hole and the weld a bolt in the hole that is for the missing stud. Then weld it in place. The repeat the cut and fit of the next "L" and weld it in place.
2.) The seat back frame cracks and splits. I riveted mine with some solid monel rivets. You can weld the frame if you don't a have a rivet gun and steel rivets. Removing the head rest is the difficult part. See http://forums.stangnet.com/showthread.php?t=478804&highlight=seat and you'll find pictures and instructions. Once the head rest is off, unzip the upholstery and slide it off the metal frame.
C
casper98gt
66
NH
Oct 9, 2007
  • Oct 9, 2007
I removed the entire seatback and lumbar cushion. Found no problems at all in any of the metal. Also my floors are mint. The interior is amazing. I couldnt find a single thing, so i came to the asumption that a large person owned it at one time.
I used force and pulled on the seat back until it came level and now its perfect. Super happy and it feels so much better. Its still kinda slow though. haha
sivart
28
  • Oct 9, 2007
in mine i lean to the left, the seat back kinda leans too. but the guy b4 me was a small guy....that just means i kan buy new seats....but ill try ur way
magnj
139
  • Oct 10, 2007
my seat has one setting, leaned back and tilted. My floorpan is fine afaik...maybe just a new seat?
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Resolved TermX AFR pegged lean after winter storage
  • Kid wita 5oh
  • Apr 4, 2025
Fox 5.0 Mustang Tech Apr 9, 2025
Kid wita 5oh
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
T
Front seats and carpet
  • Tom77
  • Sep 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
TripleYellow
