Gap between fender and door!..??
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Sep 14, 2004
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 14, 2004
  • Sep 14, 2004
Hi guys!
When I bought my car It had a gap between the fender and the door (drivers side). When I got it painted the shop fixed it But now 1 1/2 later it came back. I tryed to fix it but made it worse! , how can I fix this without bringing it to a body shop? Thanks
Here are some pics of the problem
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 14, 2004
  • Sep 14, 2004
D
dannydoo
195
Sep 14, 2004
  • Sep 14, 2004
open your hood and you will see bolts along the fender line...these bolts were probly not tightened righht .or possinly the torque from engine twist knocks it out of whack?
any way loosen these up and you will be able to slide the fender front and back..be verry carefull to not go too far or you know will damage fender and door...after you loosen the bolts you should get enough grip w.your hands to slide it along....after you align it nice tighten the end bolts to keep it straight first then the rest..
hope that helps
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 14, 2004
  • Sep 14, 2004
Thats what I did and it made it worse! . I untightened those fender bolts under the hood along with the fender bolt thats located when you open the door near the door hinge. After I did that I heard a poping sound and It never went back to place, I keep trying and trying but It won't go back.
V
v8only
2,378
22
49
Sep 14, 2004
  • Sep 14, 2004
what kind of condition are your door hinges in??
DO you have subframe connectors??? Any rust on the car? body sag??
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 14, 2004
  • Sep 14, 2004
No rust or sagging. The door closes find with a little force. No subframe connectors yet.
NO_RICE
405
Tucson, AZ
Sep 14, 2004
  • Sep 14, 2004
I had the same problem, there is a bolt at the bottom of the fender, I had a shim in there, once I took it out it lined up much better. I think that is caused by people jacking up the car under that fender. good luck.
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 15, 2004
  • Sep 15, 2004
Were exactly is the bolt? Thanks
R
Roenick97
15
  • Sep 15, 2004
you may have to unscrew the bolts to the inner splash shield to get at it. Its right at the bottom of the fender closest to the door.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
