  • SN95 4.6L Mustang Tech
gas pedal - heel toe mod
  • Thread starter Thread starter SpitfireMk24
  • Start date Start date Jun 7, 2005
SpitfireMk24
140
Livermore, CA
Jun 7, 2005
  • Jun 7, 2005
http://mustangworld.com/ourpics/fcar/99pedals.htm
I really wanted to do this on my car... but isnt this dangerous cause wouldnt you be over extending the throttle cable and be at risk of breaking it? has anyone else done this?
thanks !!!
SilverGTV8
295
West Brookfield, MA
Jun 7, 2005
  • Jun 7, 2005
It is possible to do that. Some guys make a block for under the pedal to keep if from streching the cable.
I set mine up so lite pressure on the brake pedal makes the height of the gas pedal the same, not higher.
J
JohnyD05
417
Massachusetts
Jun 7, 2005
  • Jun 7, 2005
I did it and you can tell where the bottom of the pedal is, you don't need alot of force on the pedal, because it is raised. I would definetly reccomend it.
Chili
174
Euless, TX
Jun 7, 2005
  • Jun 7, 2005
I did this but didn't go crazy with the spacer size. I made it just large enough to take up almost all of the slack. Probably about 3/4". After multiple track visits I haven't experianced any breakage, etc.
Check out this for some additional info on creating a stop for it:
http://www.cardomain.com/ride/593952/7
Y
Y2K_MustangVert
185
  • Jun 7, 2005
Mine has been fine for about a year now. The only thing you need to remember is to keep checking it to make sure it hasn't slipped. My biggest problem was getting my hands up there to tighten the clamps. Driving it afterwards will take some getting used to, because there is ZERO give on the throttle.
P
PowerJunkie
22
  • Jun 7, 2005
Yeah, if set up correctly there won't be any problems. Give it a shot!
I
impu1se
12
honolulu, hawaii
Jun 7, 2005
  • Jun 7, 2005
i used three small zip ties to space them out
propellerhead
1,541
"but what's with the but shots?"
Jun 7, 2005
  • Jun 7, 2005
I wish the dyno operator knew that when I took my car in for a dyno run. For some reason, he thought it took all 250+ pounds of force to floor the pedal. He cracked the barrel spacer so I had to make a new one.
J
JohnyD05
417
Massachusetts
Jun 7, 2005
  • Jun 7, 2005
Sorry to hear that... totally sucks, its better than breaking the throttle cable.
Pughman
295
in a galaxy far far away"MISSOURI"
Jun 7, 2005
#10
  • Jun 7, 2005
  • #10
i broke the gas pedal ! lol ... not the throttle cable , and i have this mod...
SpitfireMk24
140
Livermore, CA
Jun 8, 2005
#11
  • Jun 8, 2005
  • #11
I hear that our cars have throttle stops to prevent from damaging the trottle body... so i guess that leaves the pedal and the cable... thanks for your help guys!
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
