I have searched through the forums for about an hour and cannot find anything describing what my problem is. There is a smell of gas from the back of my engine bay on the passenger side. You can really smell it when I put the AC on. I have looked everywhere for a leak, and have found no puddles anywhere. I checked the filler neck, and that is fine. It doesn't matter whether or not I just filled the car up, it is just always there. The car is not throwing any codes, it isn't running bad, it is more of an annoyance, but I am going to mustang week in July and I don't want to drive the 400+ miles if this could be an issue.
I did just replace my PCV sensor and evap charcoal cannister because it was throwing a code, but it was happening before I did that, and continues after. I am wondering if it is an issue with the fuel injectors, but I am open to all suggestions. Thanks in advance for the help.
96 GT vert, CAI, 70mm TB, SCT Tuner, VRS catted x-pipe, magnaflow exhaust, king cobra clutch, fidanza aluminum flywheel, 3.73's, Steeda Triax shifter, SSBC brakes, H&R SS springs, tokico struts/shocks, cc plates, X2 balljoints, Steeda bump-steer kit, 17x9 &17x10.5 bullitts
