GAS TANK LEAK
B's 96 GT
47
DOES ANY OF YOU KNOW IF THERE IS A PROBLEM WITH THE 94-98 BODY STYLE HAVING GAS LEAKS? MINE JUST HAD A LEAK THE OTHER DAY AND IT CAME OUT OF NOWHERE. I FILLED IT UP PARKED IT ON BASE TO LEAVE IT FOR THE WEEKEND CAUSE I WAS GOING OUT OF TOWN AND THEN GET A CALL SAYING MY CAR HAS BEEN TOWED BECAUSE I HAD A SERIOUS CLASS 3 LEAK. THEY HAD TO CALL THE DANG FIRE DEPARTMENT. IF THIS IS PROBLEM THAT OTHERS HAVE HAD WHAT IS THE BEST WAY TO FIX IT? THANKS FOR ANY SUGGESTIONS.
1tirefire said:
I had that problem!!!!! It was the gasket from the filler neck to the gas tank. Had to go to ford to get a new one .btw it was my 98 gt
That was my problem also but it was after I installed a fuel pump. Sometimes the gasket dries up. If the leak is coming from the pipe on the right side of the fuel tank there's a good chance that's what it is.
