gas type
  • Thread starter Thread starter laserstang21
  • Start date Start date Mar 17, 2008
laserstang21
79
luling, La
Mar 17, 2008
  • Mar 17, 2008
i was always told that i have to run 93 im my 2000 mustang gt. the prince for premium over here is like 3.30 a gal. so i want to no what ocatane fuel should i be running and my car is stock except mid pipe and catback
LaserSVT
3,548
233
Mar 17, 2008
  • Mar 17, 2008
If I remember right the GTs only need regular. Does it say Premium fuel only on the gauges or on the fuel door? If not with the stock tune and your limited mods the car will run better and get better mileage with regular if thats the way it was programmed from the factory.
RedDaemon
3,470
9
108
Atlanta, GA
Mar 17, 2008
  • Mar 17, 2008
i made the same mistake when i first got my car..i put 93 in it all of the time. about a yr or so ago i realized after i smelled the car running rich, the manual says 87. ive put 87 in it ever since and it runs a lot better..even with 90k miles
H What 4.6
56
  • Mar 17, 2008
A GT's recommendation from Ford is 87+ octane ...... the 4v are the only ones they Premium is recommended..... you can run regular no problem at all..... your car might have some ping if its used to being run on premium since new but it will adjust.....
streethorse
1,042
Dallas Texas
Mar 17, 2008
  • Mar 17, 2008
You been wastin a lot of $$$$$$
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Mar 17, 2008
  • Mar 17, 2008
87 is over 3.30 a gallon here, so enjoy that price while is lasts.... use 87 unless your tuned for something else.
NobleHdwe
Oklahoma
Mar 17, 2008
  • Mar 17, 2008
Running 87 in my 03 with no pings or problems. I agree with the above it's built from the factory to run on 87.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Mar 17, 2008
  • Mar 17, 2008
What he said
I run premium in my GT though, it is pricey
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Mar 17, 2008
  • Mar 17, 2008
my car used to stall everytime i came to a stop with 87 in it and that was when i only had an o/r H and flows put 93 back in it and it ran fine since... my car would probably blow up now if i put 87 back in it
fudleyd
180
Littleton, CO
Mar 17, 2008
#10
  • Mar 17, 2008
  • #10
My car used to run better on 87 than 91 (the highest octane in Colorado) before the mods/tune. Now it's all premium over $3.30
Thankfully I have a gas friendly KIA for a DD.
Skidawg
104
#11
  • Mar 17, 2008
  • #11
Using higher octane isn't needed and is just wasting money - unless your vehicle is tuned for that.
281CI96Coupe
233
#12
  • Mar 17, 2008
  • #12
Negative. The GT's are made to run 87, but the manual clearly states if you hear pinging use a premium gas, I dont know about you, but I think thats a hint to not put 87 in. Plus 91/93 Keeps the inside of motor clean, and will not put cruddy build up on your internal parts.
People see its as waste because its not tuned for a higher octane, I see it as a investment for a long lasting motor.....
streethorse
1,042
Dallas Texas
Mar 17, 2008
#13
  • Mar 17, 2008
  • #13
Ive had 2 stangs in the last 6 years and never once had any pinging at all.
Ive tried premium for the hell off it...... no difference. So yeah its a waste of cash.
bhuff30
6,037
35
129
Olathe KS
Mar 17, 2008
#14
  • Mar 17, 2008
  • #14
If there is no detonation, then it is a waste of money to run premium. No hints, just ford covering their a$$ incase the conditions are such that it is pinging. The GT is tuned to run on 87, but any number of factors could cause it to ping. Ford doesn't want to pay for a rebuild because they didn't tell people it's ok to run premium incase the engine pings.
Run the lowest octane gas that your engine can without pinging. Lower octane has a higher energy content and you can save your money for other mods.
laserstang21
79
luling, La
Mar 18, 2008
#15
  • Mar 18, 2008
  • #15
i filled up last night with 89 and i havent heard any pinging yet and seems to run a lil better than the 93. but i did pay the same for 89 as i did 93 last week. but as long as is runs better im ok. thanks for all the the help guys
925BayArea2v
Bay Area
Mar 18, 2008
#16
  • Mar 18, 2008
  • #16
87 is 3.57 right now where i live =/ ughhhhh
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
