  • 1994 - 1995 Specific Tech
Gasoline smell!!
  • Thread starter Thread starter Cheyeter
  • Start date Start date Aug 6, 2007
C
Cheyeter
42
Little Rock, Ar.
Aug 6, 2007
  • Aug 6, 2007
I have a 94 5.0 stang, i am getting a really strong gasoline smell when i drive down the road with the a/c on. i probly get a mild smell when the windows are down but i dont notice it. I thought i might have and exhust leak but i had it looked at and was told No. i have looked in the engine bay for a gas leak and under the car, around the fuel pump. nothing. Any suggestions would help, i am stumped?? Thanks
HISSIN50
34
129
Aug 6, 2007
  • Aug 6, 2007
Look for cracked EVAP hoses (namely the line leaving the charcoal cannister, goin to the purge solenoid and then to the intake). Also check the vac line on your FPR to make sure there is no fuel in it.
If ok, visually inspect the charcoal cannister (it's inside the passenger fender, right under the antenna base). The lines at this unit can rot badly.
Good luck.
S/CBlack95GT
2,018
Tampa Palms, FL
Aug 6, 2007
  • Aug 6, 2007
Gas leaks can be hard to track down. My car had a strong raw gas smell when I popped the hood or when I parked it overnight in my garage. Turns out the FPR was leaking. Gas evaporates very quickly so a small leak will not be noticed except for the light colored stain it leaves. Check all the main things first, such as the FPR, the pressure and return line connections, and the injectors.
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
