  • 1994 - 1995 Specific Tech
gauge install problems
  • Thread starter Thread starter frcefedlx
  • Start date Start date Mar 21, 2009
F
frcefedlx
184
  • Mar 21, 2009
I installed some Autometer gauges in a friends car and the water temp and the oil pressure gauge do not register anything at all. They are electrical and first the oil gauge, it came with a sender and according to the instructions requires one wire to send a signal and has a ground and 12volt hookup on back of gauge. everything was hooked up per directions and upon powering up, nothing. Same with the Water temp gauge, came with a sending unit and nothing from it as well. The instructions say the sender grounds itself with the threads. I do not understand why they do not work any input would be greatly appreciated. I have installed gauges in my previous and present car with no problems however I do not understand the one wire signal set up. Am I missing something?
toyman
1,944
54
79
Vernon BC
Mar 21, 2009
  • Mar 21, 2009
While I'm not familar with the Autometer gauge install, it occurs to me that if you used teflon tape on the threads you may have lost your ground connection.
Powering up (turning on the ignition) may be irrelevant to gauge operation. I would think that if there is only one signal wire the temp gauge relies on a bi metal strip that creates a voltage when heated by the coolant. Same principle would apply to the pressure gauge signal wire. The 12v on the gauge may just be for illumination. As I said, I'm not familar with the Autometer setup so this is just speculation on my part.
pirotec354
127
Grand Rapids, Michigan
Mar 22, 2009
  • Mar 22, 2009
On the Autometer phantom style gauges they have two seperate power and ground connections for illumination but thats not to say that the style you used didnt. Like toyman said you may have lost your ground if you used the teflon tape. I used pipe dope on my tranny temp and oil temp senders and they worked just fine.
F
frcefedlx
184
  • Mar 22, 2009
no tape on either guage. Even tried to run a ground strap from threads to a chassis ground with no luck. I may try a different 12 volt source but I dont think that will change anything.
toyman
1,944
54
79
Vernon BC
Mar 22, 2009
  • Mar 22, 2009
For clarification. You have the engine running and up to temp but the temp gauge still reads cold and the oil pressure reads zero. Any chance that you broke or chaffed a lead wire when pulling them through the firewall? I ask as the wires for my gauges are in the 24 gauge range and can be easily broken. Have you tested the power lead with a volt meter? And the reading is?
F
frcefedlx
184
  • Mar 22, 2009
Yes the car was driven to test the water temp gauge as well as seeing 12 volts at the back of the gauges. The oil pressure does absolutely nothing at startup and I would hope it would have pressure then and the water temp does not go anywhere after a good 20 minute drive. I would think that it could possibly be a bad gauge but it seems fishy to have two bad guages.
95Vert383AOD
1,133
34
69
New Bedford, MA
Mar 22, 2009
  • Mar 22, 2009
Hmm i have a couple Autometer 1 wire sending unit gauges in my car. Did you use the Autometer sending units??? i don't believe these Gauges work with stock sending units.
HISSIN50
34
129
Mar 22, 2009
  • Mar 22, 2009
Didnt read it real closely but the guys have steered you right. Dope on the threads should not greatly hinder how the gauge works. The nature of NPT threads mean they end up with metal to metal contact. You can ohm out your sender to chassis pathway. You should see about 1 Ohm. If not, you can grab a 18+ AWG wire, put an alligator clip on one end and ground the other. Connect the alligator clip to the metal sender to ground it (this is for diagnostics). The only time I've had to manually ground a sender was when it was suspended between two runs of rubber line.
As noted, be sure to use the proprietary sender for the gauge.
Check your power and ground with a DMM biased across each. You should obviously see 12 volts with the key on. Make sure you didnt confuse the gauge-power and lighting-power wiring, which would lead to the gauge only working with the lights on.
It'll be a simple solution since both gauges are acting up.
Good luck.
ProKiller
3,064
15
78
PA
Mar 23, 2009
  • Mar 23, 2009
as Hissin said. make sure you have the power wires connected to the gauge properly. I had mine backwards on the one gauge and it didn't work. worth a shot to switch them around at the very least to rule that out.
F
frcefedlx
184
#10
  • Mar 23, 2009
  • #10
The coolant temp works now but because he is using it for the coolant in the vortech aftercooler it takes for ever to register. We will try a new twelve volt source for the Oil pressure but wont get to that for a few days. We are using the Autometer supplied sender for both guages and nothing is being used on the threads to prevent a bad ground . I think if a different 12 volt source does not fix it that would leave one of two things, bad sender or bad gauge. I still do not understand why there is voltage at the gauge but no activity.
ProKiller
3,064
15
78
PA
Mar 24, 2009
#11
  • Mar 24, 2009
  • #11
just curious, why would you want to know the coolant temp of the aftercooler? wouldn't you rather want to know the air temp going into the engine. I just don't see what that data would provide you with.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
Autometer 3318 Fuel Gauge
  • cbac89
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2025
AeroCoupe
