  • 2005 - 2009 Specific Tech
Gauge Issues
  • Thread starter Thread starter Rallek
  • Start date Start date Feb 19, 2009
Rallek
Tampa, FL
Feb 19, 2009
  • Feb 19, 2009
I have an 05 Mustang GT. It has MyColor, though I dont think that matters.
Recently the gas gauge stopped working. I have seen other people post about this, but I dont think my issue is the same. It started when I parked my car for 2 weeks. When I got back in it, the gas gauge was below E. All gauges sit to the minimum when the car is off, but the gas gauge is further down. It doesnt move when the car is started.
If anyone has had the same issue, please let me know.
I think that due to the heat in Florida, the glue that holds the needle on the pin has come un-glued. The reason I say this is a mechanical issue and not an electric issue is because the Tach is now doing it. The Tach still works, but maybe once a week it will read low, like it too has come un-glued and gravity is pulling it down.
If this is the case, Ill get some cool white-face gauges to put in there and re-glue all the needles. The Tach issue is random, the gas gauge issue is continueous. It never moves.
Again, if anyone has had the same issue, please let me know.
Thanks.
Rallek
Tampa, FL
Feb 22, 2009
  • Feb 22, 2009
Update: I havent made any progress with this issue. I have reset the EMU via battery disconnect, and by flashing it back to stock calibration, with no avail.
G
GT Dave
34
Cincinnati, Ohio
Feb 23, 2009
  • Feb 23, 2009
Any chance a mouse or other critter chewed on your wirings?
Rallek
Tampa, FL
Feb 23, 2009
  • Feb 23, 2009
Hehe. No. The car is always closed up so nothing could get in to the wires. Ill look around under hood, but I doubt thats it.
My tach messed up again yesterday but it was fine today. The needle sat low when I turned the car off, but I forgot to check it today to see how it reset itself to the correct position. Im not sure if it resets on start or not.
Rallek
Tampa, FL
Feb 25, 2009
  • Feb 25, 2009
Bump!
Rallek
Tampa, FL
Feb 25, 2009
  • Feb 25, 2009
Someone recomended to remove the rear seat and check the electrical connections on both sides of the tank, and possibly add some electrical grease.
Removal of the seat is easy, theres are 2 buttons under the front of the seat. Push em and lift up on the front. Remove the 2 big round cromits. I just disconnected and reconnected the plugs a few times, as I dont have any electrical grease. When I started the car... Ta-Daaa, the gas gauge moved. This process took me all of 5 mins. There is alot of dirt in between the tank and the frame, so Im guessing dirt is the issue Ford has been having with this.
But! My Gas Gauge and Tach still dont read correctly. Im pretty sure its a mechanical issue in the dash because my needles jump, kinda like a second hand on a ticking clock. So either the pin is not tight in the needle hole, or the needle is falling off. See! My car's so fast the needles cant hang on! Anyways, I'll be taking the dash apart at some point and puting a bit of glue on the needle shafts.
Rallek
Tampa, FL
Mar 3, 2009
  • Mar 3, 2009
Update:
Stepper Motors! It has been suggested and confirmed that my issue was the stepper motors in the gauge cluster. They are apparently bad in some '05 cars. You can order these from Ford or get them on Ebay(that's where I found them). If you can solder, these can be purchased individually. It is suggested to replace them all. I found a service on Ebay that does this, you just have to ship off your gauge cluster. Usually takes a week.
G
GT Dave
34
Cincinnati, Ohio
Mar 3, 2009
  • Mar 3, 2009
What is the fix going to cost you?
Rallek
Tampa, FL
Mar 4, 2009
  • Mar 4, 2009
You can buy the motors for about $8 each, but you have to be good with electronics, and able to solder. He charges $140, plus you pay the shipping to get the cluster there. Do an Ebay search for 'Mustang Stepper Motor'.
bigbirdwpg
14
Winnipeg, Manitoba Canada
Mar 5, 2009
#10
  • Mar 5, 2009
  • #10
Thanks.
The needles on my '05 are not glued. They just press on. You can turn them, which makes it hard to get them right if you do a white face change, which I did. I had problems like you describe and I just disconnected the positive cable on the battery, waited a few minutes and reconnected and all worked again.
BTW I ended up taking the white face off because of visibility issues. Looked good at night with the mycolor, but I couldn't see them well under bright conditions.
Rallek
Tampa, FL
Mar 13, 2009
#11
  • Mar 13, 2009
  • #11
Good info. Thanks.
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
