gauge wiring
or you can grab the dimmer wire at any dimmed component (radio, dash clock, etc). i used the dimmer wire at the headlight switch (dont recall color, so we will go with juiced). it was on a corner of the switch connector, IIRC. use a test light and run the dimmer to make sure the rheostat dims the test light.
good luck.
