  • SN95 4.6L Mustang Tech
Gauges Going Crazy
  • Thread starter Thread starter 00PearlGT
  • Start date Start date Jan 22, 2007
00PearlGT
Banned
Jan 22, 2007
47
  • Jan 22, 2007
I recently purchased an 00 GT from a local guy. Earlier today I noticed the check engine light came on only days before my smog. WOOHOO!! Anyways I went to lunch today from work and during startup the gauges went stright to redline, back down to zero, and then a second later the rpm's read normal. I turned the car off and started it 2 more times and it did the same thing. Then leaving the togos it started up with no problem. The car has 53k miles and idles perfectly with no sign of misfire. Any ideas?
mustang90
1,209
15
58
Jan 22, 2007
  • Jan 22, 2007
sounds like the computer was resetting itself. typically our cars do that after you disconnect the battery to reset the gauges. don't know what caused this. check your battery connections first.
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 22, 2007
  • Jan 22, 2007
I agree that it sounds like your PCM (computer) is resetting itself. My guages did this every time I disconnected the battery for maintenance or addition of mods. Check your battery terminals and cables first for corrosion and/or breakage.
00PearlGT
Banned
Jan 22, 2007
47
  • Jan 22, 2007
It seems to be a pretty old battery but the connections look good. Alos when I turn my headlights on my left headlight tends to flicker or shut off when I'm driving. I'll come to a stop and it'll shut off then when I drive it comes back on. Only the left headlight does it. I do have a check engine light so could there be some kind of code for electrical issues like this?
blubullett
535
Modesto, CA
Jan 22, 2007
  • Jan 22, 2007
Mine used to do that (except throwing codes) and it was just the battery terminals were a little bit loose. Check where the ground connects to the car also.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 22, 2007
  • Jan 22, 2007
That is a classic symptom of a bad battery, loose connection/bad ground, or a bad battery cable.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Jan 22, 2007
  • Jan 22, 2007
Start with the cheap stuff: get your alternator checked (AutoZone, free), get your battery checked (AutoZone, free), inspect your battery, and you might even want to service the battery while you're at it.
It's good to service the battery every 6 months.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 23, 2007
  • Jan 23, 2007
another possibility is a dead cell within the battery. Get it tested, if the battery checks out then I would suspect loose wireing or a bad ground.
fast97gt
1,082
north carolina
Jan 23, 2007
  • Jan 23, 2007
i agree somethin wrong in the charging system but have the alt checked and make sure its not over charging before you buy a new battery if you dont youll ruin the new battery and we all no its not fun waisten 75 to 100 bucks on stuff
Tripoli
208
Dallas, TX
Jan 23, 2007
#10
  • Jan 23, 2007
  • #10
I recently had the same thing happen. Turns out a week later my batter was toast. Replaced. No problem since.
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
