Gauges tripped out
  • Thread starter Thread starter millhouse
  • Start date Start date Apr 23, 2009
millhouse
1,985
Simpsonville, SC
Apr 23, 2009
  • Apr 23, 2009
I originally posted a help topic on my tach not functioning….but now I’ve realize something else may be the culprit.
I used to have some crazy buzzing noises coming from the back of the instrument cluster….and one day the tach finally quit. I figured this was an isolated issue…and that I simply needed a replacement. Well, I’ve now realized that my battery gauge is no longer functioning (voltage from the alt is fine) and my factory temp gauge get’s pegged. The low batter light also trips….and lights up ever so dim. I’m unsure if the fuel gauge has been affected yet, but I did recently run out of fuel…thinking I had more. The dash lights remain working fine however while all of this occurs.
Is there a check-list on possible causes for some of these issues?
Edit:
Ok, after a search it seems that this could possibly be a grounding issue. I wasn’t thinking this as the lights are still functioning as is the oil pressure gauge. I’ll check them tonight…but which ones in particular seem to be an issue?
Also, it seems there is a possibility the issue lies with the IP voltage regulator. Where is this located…and how do you diagnose?
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Apr 24, 2009
  • Apr 24, 2009
Edit:
MILLHOUSE!! Whats up dog!!! WOW, haven't seen you in ages! ( I used to be Willys1)
Not sure about your dash. My lites are starting to drop like flies. All I can see when its dark is my tach.
millhouse
1,985
Simpsonville, SC
Apr 24, 2009
  • Apr 24, 2009
Hey hey....what's happening!!!!!
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Apr 24, 2009
  • Apr 24, 2009
Not much buddy, nice founding member ct!
millhouse
1,985
Simpsonville, SC
Apr 24, 2009
  • Apr 24, 2009
Yeah...what can I say, I worked hard for it!
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Apr 24, 2009
  • Apr 24, 2009
I think Willys1 would have had one by now. If he didn't get banned. "Again"!
ID89GT
1,659
18
49
Spokane Valley, WA
Apr 25, 2009
  • Apr 25, 2009
I may be having a problem similar to yours. When the car is running all the gauges will like drop down and the lights will all dim, happens about every 5 minutes or so. Also the car surges like power is lost. I've checked all th grounds and all look good? Idk
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
