  • SN95 4.6L Mustang Tech
gauges
  • Thread starter Thread starter OD
  • Start date Start date Mar 30, 2004
OD
323
Calgary, Ab Canada
Mar 30, 2004
  • Mar 30, 2004
i just finished installing autometer gauges... ran into a few probs..
1. oil pressure is reading over 100, like the needle is pinned all the way to the right
2. water temp, not too sure if i should replace the stock one (i think there it two) or drill the thermostat housing...
any help?
thanks
Dr. Wu 2000
554
Eastern, Pa.
Mar 31, 2004
  • Mar 31, 2004
I'm pretty sure that your oil pressure should be around 75psi while
driving and 25 at idle, at least that's what mine are. 100 sounds a
little high. I am assumming that you have a a-pilllar gauge cluster.
I was able to keep all the factory gauges working by having an
adaptor installed. I had a performance shop do the install. I've
heard horror stories of trying to do the install yourself if your not
sure what you are doing. Have a speed shop do it for you and do
it right. Good luck.
S.D.-Stangman
580
San Diego, Ca
Mar 31, 2004
  • Mar 31, 2004
I used the drain plug on the drivers side of the block for the water temp. Think I had to buy an adapter from autometer, but it worked like a charm.
As for oil temp, mine runs pretty high when the car is cold, but after it warms up, it stays at 25-30 @ idle, 60-80 on the highway depending on RPM's.
9
96GRIMREAPER
21
  • Mar 31, 2004
any help?
thanks
where did you put the water temp sender?? i really need help.
S.D.-Stangman
580
San Diego, Ca
Mar 31, 2004
  • Mar 31, 2004
there is a brass plug on the drivers side of the engine block, above the oil pan. If you put the front end on stands and get under there, you will see it. Cant miss it. ther eis an adaptor you will need from autometer. dont remember the size, but i know it is blue aluminum, so you can match it to the picture on their site.
OD
323
Calgary, Ab Canada
Apr 1, 2004
  • Apr 1, 2004
ya i heard other suggestions of drilling out the thermo housing.. i dont like that idea.. ill see if i can get that adaptor for the freeze plug.. and as for the oil, it did come with an adaptor but i was under the impression if was for fuel pressure, i havent given much of a chance to warm up tho... dont get it insured until today
thanks everyone
OD
323
Calgary, Ab Canada
Apr 3, 2004
  • Apr 3, 2004
anyone know of the link for that adaptor for the temp sensor?
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
