  • 1994 - 1995 Specific Tech
Gauges....
  • Thread starter Thread starter Guero
  • Start date Start date Jun 9, 2006
Guero
2,148
Jun 9, 2006
  • Jun 9, 2006
Well i got my new lifters and pushrods, there soaking in oil, amnd will continue to soak, for a coupe of days lol. well any way, i bought 3 gauges at the same time. Water temp, oil pressure, and an a/f ratio. I got them on the pillar, all hooked up to each other(grounds, power,0 except the power for the a/f one since it needs to be connected to the key. My question is the a/f gauge has a purple wire that connects to the o2 siganl wire that connest to the pcm. were would that wire be? and what color, the temp and oil look so easy to connect, i cant beleive i wanted someone to install them!!!!!!!!!
bill302
2,131
alabama,gadsden
Jun 9, 2006
  • Jun 9, 2006
o2 signal wires (ho2s) run from the pcm to the o2 sensors the ho2s left sensor signal wire is red/black and the ho2s right sensor signal wire is gray/light blue....
1TallMF
955
Montreal
Jun 9, 2006
  • Jun 9, 2006
Guero, did you end up getting that gauge pillar pod you were looking at on ebay?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 9, 2006
  • Jun 9, 2006
If you got the tinted ones on eBay let me know how good you can see them in the day, Im thinking about getting some.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 9, 2006
  • Jun 9, 2006
the purple wire on the gauge connects to Pin number 43 at PCM, red w/black stripe or Pin number 44, gray w/light blue stripe
Guero
2,148
Jun 9, 2006
  • Jun 9, 2006
no i got the auto meter ones from summit, they look so badass!!!!!!!!!!!!
The Green GT
1,269
Louisiana
Jun 9, 2006
  • Jun 9, 2006
What line did you get?
Guero
2,148
Jun 9, 2006
  • Jun 9, 2006
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-3375&N=115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-3337&N=115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-3327&N=115&autoview=sku
and the 3 gauge pillar
1TallMF
955
Montreal
Jun 9, 2006
  • Jun 9, 2006
Sweet, hopefully you can get the motor running soon so they can be used for their intended purpose
Guero
2,148
Jun 9, 2006
#10
  • Jun 9, 2006
  • #10
lol dam you!!! you had to remind me!!!lol
4Jenna
4,326
AZ
Jun 9, 2006
#11
  • Jun 9, 2006
  • #11
Why did you get the A/F to watch the purty colors?
hehe
Guero
2,148
Jun 10, 2006
#12
  • Jun 10, 2006
  • #12
so when i spray. im not running lean! but i like purty colors to!!!!!!!!
urban96
3,464
Syracuse, NY
Jun 10, 2006
#13
  • Jun 10, 2006
  • #13
he means they arent that accurate on the stock narrow band O2 sensors, i think ours even turn off at WOT
if you buy an innovate motorsports LM1 wideband kit youll know your A/F is accurate. it also has an analog output you can hookup to your autometer gauge
mytight95
2,605
Dothan,Al
Jun 10, 2006
#14
  • Jun 10, 2006
  • #14
very good info there, i had one for a couple days, i connected it to the o2 harness on the outside of the car until it melted, (layed on the exhaust)
jason
4Jenna
4,326
AZ
Jun 10, 2006
#15
  • Jun 10, 2006
  • #15
Yup...wideband is the only way
Guero
2,148
Jun 10, 2006
#16
  • Jun 10, 2006
  • #16
yeah i was gonna get the wideband, but i had to spend an extra 800 bucks to fix the ride again, i have no more money for mods
Guero
2,148
Jun 10, 2006
#17
  • Jun 10, 2006
  • #17
jason
same as mine? how did it work?
Guero
2,148
Jun 10, 2006
#18
  • Jun 10, 2006
  • #18
ok there all installed!!!! piece of cap, i just need to connect the sender wire to were they belong but i have to wait so i can run the wires with the injector connectors. this was like a 3 hr install, icluding hiding the wires putting, the pillar on, going to checkers once, and all that good stuff!!!!
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
