  • 1994 - 1995 Specific Tech
Gauges
  • Thread starter Thread starter Guero
  • Start date Start date Aug 3, 2006
Guero
2,148
Aug 3, 2006
  • Aug 3, 2006
My OIl Pressure gauge moves up when i press on the clutch all the way, and my temp gauge goes down when i hit the clutch all the way. Aftermarket ones. And my temp reads really high like at 250, and my stock is in the middle. and when i hit the clucth it usually goes down to 210, were i think it really is. what the hell is wrong? Is my car overheating or not? Is there another way to get the reading of the temp????
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Aug 3, 2006
  • Aug 3, 2006
If they more like that then the temp is more than likely fine, just the connections are screwed up. I would check all the connections on the back and on the senders. And see if any wires are hanging under the clutch petal and getting pinched.
Guero
2,148
Aug 3, 2006
  • Aug 3, 2006
ok, is there any thing connected to the clutch like a negative or positve that tells the computer something?
The Green GT
1,269
Louisiana
Aug 3, 2006
  • Aug 3, 2006
The switch that tells the ignition that the pedal is down, that all I can think of. But if wires are getting pinched, then they are prolly grounding, and that why they are moving.
Guero
2,148
Aug 3, 2006
  • Aug 3, 2006
true, but if they were getting grounded wouldn't they turn of? I may have connected the ground to the clutch or something Ill check tomorrow
The Green GT
1,269
Louisiana
Aug 3, 2006
  • Aug 3, 2006
No, grounds are what makes the needle move. The more they get grounded, the more the needle moves. The (+) is constant, but the ground changes with the signal, and that is what makes the needle move.
I think. Im pretty sure actually.
Guero
2,148
Aug 3, 2006
  • Aug 3, 2006
i really have no clue about electronics, i thought + was the one that made everything move.
The Green GT
1,269
Louisiana
Aug 3, 2006
  • Aug 3, 2006
Electronics are confusing. Its not something someone can teach someone else over the internet in a single post.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
