gauges
  • Thread starter Thread starter ras50gt
  • Start date Start date Nov 12, 2006
ras50gt
200
  • Nov 12, 2006
Im planning on getting a supercharger in the near future for my 93 GT, I was just wondering what gauges you guys install to monitor everything. I was thinking of two or three gauges on the pillar, then maybe the gauge holder that fits into where the heater vents are. What do you recommend?(boost, fuel pressure, oil pressure) What other gauges should I think about getting? (water temp, air/fuel ration, EGT). Which do you like better as far as the pillar gauges, two or three? And I read somewhere that an EGT gauge is better than an air/fuel gauge, is that true? What exactly is an EGT gauge? Post pictures if you have them.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 12, 2006
  • Nov 12, 2006
EGT gauge is a Exhaust Gas Temp gauge.
HISSIN50
34
129
Nov 13, 2006
  • Nov 13, 2006
I'd want fuel pressure and boost for the blower. OP and water temp are requisite for mods like that (or less) as well.
A wideband would be sweet - it wont likely be going in a pod though.
Good luck.
millhouse
1,985
Simpsonville, SC
Nov 13, 2006
  • Nov 13, 2006
I have water temp, boost & air/fuel in the A-pillar. You can see them in a write-up I did in this thread....http://forums.stangnet.com/showthread.php?t=634260
Although I don't have them yet...I'll be getting a matching oil and fuel pressure gauge and stick em in one of those pre-formed cowls you always see in the adds.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Nov 13, 2006
  • Nov 13, 2006
I wouldn't really worry about an EGT sensor with a supercharger, this is more of a requirement for Turbo charged vehicles. If you have an automatic, you might go with a transmission temperature gauge. It looks like you've got most of them covered.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 13, 2006
  • Nov 13, 2006
If you get a AFR gauge make sure you are getting a wide band. Otherwise its a usless gauge just a light show only really works at an idle. I would have a boost gauge and your oil pressure and water temp and fuel pressure aswell.
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Nov 13, 2006
  • Nov 13, 2006
Boost, water temp, & oil pressure in the pillar.
if you REALLY want...id suggest oil temp and tranny temp in the dash.
ras50gt
200
  • Nov 13, 2006
millhouse-those blue LED are nice. What do you think the black light would be like? I also have a autogage 5" tach, is it possible to swap out the bulb in that? it has a white one in now? Hmmmm, maybe I will just leave the lights stock until something goes out.... But I guess its something to think about before buying the boost and other guages, it would be nice to match everything. Keep the posts coming, and pictures. I think the red would look sick, I think you might have mentioned how this can be done but not sure.
millhouse
1,985
Simpsonville, SC
Nov 13, 2006
  • Nov 13, 2006
The black lights wouldnt light up bright enough. Really, the blue lights are as far as I'd go...and they too are more dim than the standard bulbs.
ras50gt
200
#10
  • Nov 18, 2006
  • #10
Anyone have pictures of the autometer sport comps in their cars? If so post them up. Anyone with double or triple pillar gauges, post some pics. Also, as far as fuel pressure gauges, would you recommend 0-100 psi? Should I go electrical or mechanical on some of these? And for the boost gauge, do you recommend the gauge that has both vac/boost? Thanks guys.... Post pictures!
Hi-Po
106
Oslo, Norway
Nov 18, 2006
#11
  • Nov 18, 2006
  • #11
I am running a KB supercharger, and have A-pillar mounted fuel pressure and boost guage. Way easier to monitor them there instead of in the heat vents.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
  • dan50
  • Jul 18, 2026
dan50
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
