gear install ?
  • Thread starter Thread starter tkareno
  • Start date Start date Aug 20, 2007
tkareno
67
clinton ct
Aug 20, 2007
  • Aug 20, 2007
in order for me to get my gears installed and bring it to a place i just pull my tranny out right?
bloopbloob
578
Alberta
Aug 20, 2007
  • Aug 20, 2007
huh??? pull your tranny for a rear gear install then tow it to a shop?????
RYC CUKR
1,437
Orlando
Aug 20, 2007
  • Aug 20, 2007
In general when guys refer to "gears" they are talking about the ring and pinion gears in the differential. This is the rear axle housing. I have always taken the gears and the car to the shop and had them install them. Unless you have a bunch of other issues it should be in and out in a day depending on how busy they are.
tkareno
67
clinton ct
Aug 20, 2007
  • Aug 20, 2007
so i dont take my tranny out at all and yes im talking about the ring and pinion
jtfairlane
468
  • Aug 20, 2007
UUUUUUHhhhhhhhhh....no. No, leave your transmission alone, it has nothing to do with your ring & pinion gears.
In fact, when you take it to a shop and they put it on a lift, have them show you what is what, and explain in a nutshell what it does.
tkareno
67
clinton ct
Aug 20, 2007
  • Aug 20, 2007
ok thank you
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
