gear preload ??
  • Thread starter Thread starter 2002BLGT
  • Start date Start date Nov 4, 2005
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 4, 2005
  • Nov 4, 2005
got the ford racing axles in , put it all together last night with new ring and pinion and all new bearings and races throughout the whole rearend ......the mesh was as good as any I have ever seen and the backlash was checked in 5 spots .008 .007 .009 .008 .008 so I left it at that ......
only thing questionable is the preload because I didnt have a beam torque wrench ......so I used the good old wrist on it and only put it a tick tighter than normal since I put new bearings in ......the car now has a little whine on deceleration , could adding a touch more preload fix this ?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 4, 2005
  • Nov 4, 2005
anybody ?
nosmatt
1,356
Bass Lake, Ca
Nov 4, 2005
  • Nov 4, 2005
no.
you would HAVE to remove the crush sleeve, and start over. the only way adding some torque can be done without total remove of the pinion gear, is if you use a solid pinion spacer. then loosen, and retorque....
so, i assume you tightened the pinion nut till the slevve crushed, and all the play was gone, then added some more torque till the pinion was harder to turn than no preload????
i think it is backlash related.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 4, 2005
  • Nov 4, 2005
nosmatt said:
no.
I double checked the backlash 3 times ......I think I am going to give it about a 1/16th turn tighter on the pinion nut to give it a little more preload and see what happens , if that doesn't do it then I guess I will have to pull it back apart , I have done 3 sets of gears in the last 2 months and mine are the only ones making noise ...but mine is the only one that has gotten all new bearings installed ...... its not unbearable but its there definitely on decel .....the coast and drive side mesh look good .....I guess I should have stayed with the old bearings uuuuggggghhhhhh.........
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
