  • SN95 4.6L Mustang Tech
gear question
  • Thread starter Thread starter reezy
  • Start date Start date Sep 3, 2004
R
reezy
21
  • Sep 3, 2004
im looking at getting some 4.10 gears for my stang and paying a shop to have them installed, but my question is...how do these gears work? forgive me for knowing next to nothing about cars but in the picture it looks like 2 gears...shouldnt there be five of them? can someone explain please
7000rpmisheaven
293
  • Sep 3, 2004
The small cone shaped gear is called the pinion gear. It basically connected to the end of the driveshaft. The circular gear with the hole in the center is called the ring gear. The rear axle basicly goes right through the the center of the ring gear and has the rear tires on either end. The driveshaft turns the pinion gear whose teeth push the teeth on the ring gear and the ring gear turns the rear axle. This is the general principle.
W
wickedgt70
178
San Jose, CA
Sep 3, 2004
  • Sep 3, 2004
There should only be 2 gears. I would assume that by saying "5 gears" you are thinking of the transmission gears...i.e. a 5-speed tranny. These are rear-end gears. These go into the rear axle of the car, not the tranny. By changing the gears in the rear end you are effectively changing the ratio of every gear in the tranny.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
