Gear Ratios?
pygmypony
Been wondering about gear ratios as I prepare for an SVO 5spd and rear swap into my 86 coupe. Right now I think I have a 3.33:1 ratio in the 7.5 rear end. Is that right?
Also, the SVO I believe has a 3.7 rear gear and a .73 OD? I'm trying to figure out the effects of ratios on the car before I go gung ho and swapping parts. I'd even try a shorter tire to help balance out any disparity
Is your car a manual?
I'm not totally sure about the pre-87's, but I'd venture a guess that your car probably has the 3.45 gears in the rear (those were standard issue behind the manual trans in Mustangs and Thunderbirds for several years)
SVO's had 3.73 gears (same as 5 speed 2.3L Mustangs), but they had different transmission ratios than other 2.3L cars. .78 OD, according to this chart, which is pretty handy: http://www.fordmuscle.com/archives/2000/09/t5swap/index2.shtml
My TC has 3.55's in it (of course, 8.8 rear) and I think they're about perfect behind a 2.3T.
