Suggestions for rear diff gears - 1969 Mach 351W 4v
cfauvel
86
Sarasota,Fl
My Mach 1 was born with a 3spd TopLoader and 3.00:1 open diff (not going to lie ...that combo sucked)
A while back I swapped in a 1993 or so Tremec T5 (I love it BTW) , but the performance is still pretty low....so this year I am going to get a whole complete center section for my 9" rear diff and I'm vacillating between the the 3.50:1 , 3.70:1, and 3.75:1 Eaton TrueTrac helical-gear carrier (the TrueTrac is what I am going to go with)
What are you guy's thoughts?
the T5 should have these gear ratios
1 - 2.95
2 - 1.94
3 - 1.34
4 - 1
5 - .63 OD
UPDATE 04/09/2024) correction...my T5 is 1990 variant
1 - 3.35
2- 1.99
3 - 1.33
4 - 1
5 - .68
That taller 1st gear with a 3.70 rear ratio, might be much....3.70X 3.35 = 12.395:1 effective ratio
I've been playing with this calculator to see what some of my numbers would be.
I have an old Stewart Warner tach from the 60s on the steering column that I am suspect of in regards to accuracy.
Also note: I am running too small of tires 225/60r14......which should be around 24.6" diameter
I'll probably go to a more appropriate tire size of 225/70r14 ....which should be around 26.4" diameter
I'm looking for off the line quickness than top speed or 1/4 mile speed....more like better 0-60 times....(right now it is super embarrassing, but I still get thumbs up, because of the car, not its performance)
Thanks
What are your guy's thoughts?
:worthlesb
--and--
:spot:
Get the 3.70 rear gears
Yeah I think I've resigned to the 3.70 ratio....I have to pull the car out and undo the rear U-joint to re-measure the amount of play I have at the slip yoke.
This will steer me to the right pinion yoke....I have a long 1310 currently, but I think my amount of slip is pretty small...MAYBE 1/2" or less. A short 1310 is 1" shorter so that would put me in a 1" + (unknown) worth of slip which is probably a bit too much depending how long the slip yoke is and how far the splines go into the slip yoke...
I haven't had any troubles with the current slip yoke, driveshaft, and pinion yoke....but if the slip is way less than 1/2" then I'm afraid of bottoming out the slip yoke onto the output shaft of the transmission...
That is the hold up right now. Which pinion yoke to go with.
I know my car is a 93 but driveline is driveline. I have a 92 WC T5 with the same gear ratios as yours has and if I could redo my rear gear selection I would have gone with 3.55’s. Rear tires are a 275/40/17 drag radials which are 25.67” and first is just a little too much with the 3.73’s. Car has right at 370 rwhp for reference. 3.55’s would have been my preference but I don’t drive the car enough to justify the gear change cost.
Great looking Sportsroof man!
Reactions: cfauvel
Ugh....decisions decisions
note: the 1969 Mach1 351W probably has less than 200 RWHP...probably closer to 150-175 Hp
