91 lx hatch New Member Jun 8, 2007 11 0 0 Jun 8, 2007 #1 Jun 8, 2007 #1 can i just swap my 3.08 gears for some 3.73 gears and use the same shims if backlash is ok or should i use new ones
RYC CUKR Founding Member May 19, 2002 1,437 1 38 Orlando Jun 8, 2007 #2 Jun 8, 2007 #2 Shims are shims. As long as they aren't broken or cracked you can reuse them. Of course this is only as long as the backlash is ok.
D DRock9 New Member Aug 22, 2006 359 0 0 Jun 8, 2007 #3 Jun 8, 2007 #3 If your rear isn't making noise now then it won't when you are done, you do not need to replace them unless they are broken or cracked like RYC said.
