  • 1994 - 1995 Specific Tech
Gear tooth count
  • Thread starter Thread starter DMacRacer
  • Start date Start date Dec 7, 2006
D
DMacRacer
28
  • Dec 7, 2006
Anyone know the Ring and Pinion tooth count on 3:73 gears? Is it true you can divide the pinion gear count by the ring gear count to get the ratio?
Thanks.
drakesdad
961
Oregon OHIO
Dec 7, 2006
  • Dec 7, 2006
Thanks.
Yes......I didn't believe it but the guy that changed my 3:27's showed me. I'm not sure it was the other way around but he had me count the teeth and he did the math...lol
drakesdad
961
Oregon OHIO
Dec 7, 2006
  • Dec 7, 2006
I'll make it easy for you...........................lol
http://www.tyres1.com/calculators.html
drakesdad
961
Oregon OHIO
Dec 7, 2006
  • Dec 7, 2006
I have been told of this method as well to verify what is in your car if you cant read the plate or it has been changed.
http://www.getahelmet.com/jeeps/tech/findratio/
D
DMacRacer
28
  • Dec 7, 2006
Thanks, all that helps out. I also read in a Ford Performance book that with 26 inch diameter tires with 3:73 gears I should be at around 1900 rpm at 60mph.
That is what I'm at if the speedometer is correct.
BlackVert
5,589
9
98
Bethesda, MD
Dec 7, 2006
  • Dec 7, 2006
yep ring tooth count / pinion gear count
iirc i think it is 36 ring teeth and 11 pinion teeth
36/11 = 3.272727
D
DMacRacer
28
  • Dec 8, 2006
Did the old turn the drive shaft and tire and counted each turn, 3 3/4 for the drive shaft to one turn of tire and per the link above I should have 3:73 gears as the seller told me.
Thanks for the link
drakesdad
961
Oregon OHIO
Dec 8, 2006
  • Dec 8, 2006
Thanks for the link
Glad to help...............and I forgot...................
Welcome to :SNSign:
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Thinking of selling my stang.
  • 2003 mustang gt modded
  • Mar 26, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 26, 2026
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
