Gear tooth count
Thanks, all that helps out. I also read in a Ford Performance book that with 26 inch diameter tires with 3:73 gears I should be at around 1900 rpm at 60mph.
That is what I'm at if the speedometer is correct.
Did the old turn the drive shaft and tire and counted each turn, 3 3/4 for the drive shaft to one turn of tire and per the link above I should have 3:73 gears as the seller told me.
Thanks for the link
