Gears and incorrect speedo
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date
D
First of all, I just had my 4.10's installed and Im going to immediately say, "These should have been my FIRST mod". Good God.
Anyway, I know my speedo is now off (obviously) and I dont have a tuner *yet*. So typically, how much is the speedo off (in terms of MPH)? I need to keep track of it while Im driving.
Stock wheels/tires, 4R70W auto, just with 4.10's.
It will read 4.10/3.27 = 125% of your real speed (and also rack up those extra fakes miles too).
To correct it you need to multiply by 100/125 = 80%
Gears are fun huh!!! Hope you have nice big rear tires!:nice:
I'd get a speedcal ASAP. I incorrectly set my speedcal so I was doing 30 MPH and it showed 150. I racked up 7 miles in like 2 real miles.
Ford Mustang: Mustang Tech: Calculators & Decoders: RPM Calculator
3.27: 50 is @ 1433 RPM
4.10: 50 is @ 1797 RPM
So now drive at 50 MPH in 5th gear @ 1797 RPM and see what your MPH is. Assuming you have a .67 5th gear ratio. Or @ 60 MPH you should be at 2157. This is with stock tires.
Arent your shift points all messed up now? I was under the impression that you had to have a tuner in order to put the gears in or youd destroy your trans.
Well, I manually shift the auto (I know I know, its bad) about 90% of the time Im driving it so I really haven't noticed any problems with it. I'll definitely keep an eye out for that though.
The speedo is being a lot bigger problem then I anticipated it would be. The difference is between actual speed and indicated speed is more than I had thought. Going in, I thought that it would be a set number that I could easily keep track of while driving.....wrong.
Im buying a handheld tuner within the next few weeks for sure. The GT isn't my DD anyway, so its going to have to spend the majority of the time sitting :notnice:
I really wouldn't do that. Dallas mustang had a speedcal many years ago, not sure who has them now.
