  • SN95 4.6L Mustang Tech
Gears FINALLY.........................................
  • Thread starter Thread starter east_sidaz40
  • Start date Start date Jun 29, 2005
east_sidaz40
189
  • Jun 29, 2005
guys, the 3.73's are great . I love em. Only problem is that when i turn Right , not left only right. I hear a strange sound like metal rubbing "slightly". Its freaking me out. I called the guy who installed it and he told me its the "clutch" inside the gears!!!???? what the hell is that, anyone know about this? is it serious??
any info will be Great in this time
T
tjm73
2,418
Rush, NY
Jun 29, 2005
  • Jun 29, 2005
Did the new gear oil have friction modifyer in it? If it did not, did friction modifyer get added seperately?
east_sidaz40
189
  • Jun 29, 2005
yes it got added seperatly!!
T
tjm73
2,418
Rush, NY
Jun 29, 2005
  • Jun 29, 2005
Hmmmmmmph........Without hearing it all I can say is it shouldn't be making any grinding noises. Get it checked out before you burnout the trac-lok or something worse happens.
east_sidaz40
189
  • Jun 29, 2005
I just came back from another test drive. i thought since its NEW it will be there only at first. But its still there. I'm going to the dealership to get it checked out tomorrow . thanks for the help
SilverGTV8
295
West Brookfield, MA
Jun 29, 2005
  • Jun 29, 2005
Dealership? Take it back to the guy who did it. If it was fine before and now it's not then he did something incorrect. Ford won't touch it (my dealership won't) if they find it has another ratio out back.
A
Azarello
115
  • Jun 29, 2005
How do you like that mac cai?
RedBullitt
462
Morgantown WV
Jun 29, 2005
  • Jun 29, 2005
what would the rear end have to do with turning right?
east_sidaz40
189
  • Jun 29, 2005
well to be honest. I kinda paid a guy that works for ford to come work for me overtime.since they got all the right tools.and when i take the car this morning to ford for a regular check up , I will call him and tell him to check that strange sound on the 3.73
east_sidaz40
189
#10
  • Jun 29, 2005
  • #10
ummm . well its just mainly for show. It looks good thats all i can say , and it has a nice sound
east_sidaz40
189
#11
  • Jun 29, 2005
  • #11
i have NO IDEA myself, thats what i was thinking. rear end?? turning??
it shouldnt be connected!!!! I hope it wont be from my 3.73 . when they put the car down of the jacks. I heard some metal falling. maybe they forgot to instal a part back , maybe thets why i'm getting that sound
I just hope its not anything serious. I'll keep u guys posted. I'm going there after an hour
Chili
174
Euless, TX
Jun 29, 2005
#12
  • Jun 29, 2005
  • #12
Bear with me here but this is my understanding. When you go around a corner your inside wheel spins at a slightly slower rate the outside (the radius of the turn is larger for that wheel therefore it is traveling farther and faster, think "crack the whip"). That is one of the the benefits of the limited slip and is why daily driver cars don't want a spool (it will not allow the tires to turn at different speeds causing one wheel to lose traction). That said, I would guess it has something to do with the diff and how everything interacts.. Most likely the install was not done correctly.
east_sidaz40
189
#13
  • Jun 30, 2005
  • #13
okay here is the UPDATE. i came back from FORD just now. the mechanic there said to me and i quote "your axle bearing needs to be changed and also your axle because it looks like its bent". he told me all this withought pulling out the axle. because the right wheel vibrates a bit.And he says the axle is not fit properly. So i hope its just the bearing that needs to be changed not the AXLE as well . so i dont know now , they told me they will let me know once the pull out the axle. I think the instal was not done that well.
any comments!?
Give Me TP
936
Republic of Texas
Jun 30, 2005
#14
  • Jun 30, 2005
  • #14
There is nothing done during a basic gear change that involves the axles other than removing two C-clips (I think) and pulling the axles out, followed by sliding them back in and replacing the C-clips. Also nothing is done internally to your differential. If the noise you are hearing was not there before the gear change the installer has not done something correctly when replacing the differential and/or axles back into the rear housing following the gear change, and should correct the situation gratis.
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#15
  • Jun 30, 2005
  • #15
any comments!?
I'm not saying the axle couldn't be bent, but it strikes me odd that it's "bent" all of a sudden after the ring and pinion install. Did it make any kind of noise or have any odd vibration before the gear install?
east_sidaz40
189
#16
  • Jun 30, 2005
  • #16
the car was runing GREAT before the instal. it all came after . ANYWAYS ....here is the final update i guess: FORD told me they will pull out the axles see whats up , and do it all along with any part change under the warranty. The axle might not be bent, i think its something to do with the axle bearing. or when the guy pushed back the right axle , he didnt fix it right or something , thats all I HOPE
hotdog71
427
Seattle, Eastside
Jun 30, 2005
#17
  • Jun 30, 2005
  • #17
Maybe the C clip bearings got put in the wrong way or I mean swaped from left and right or even damaged..
good luck.
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#18
  • Jun 30, 2005
  • #18
hotdog71 said:
Maybe the C clip bearings.....
C-clips or bearings. There are not c-clip bearings.
C-clips are interchangeable side to side.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Thinking of selling my stang.
  • 2003 mustang gt modded
  • Mar 26, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 26, 2026
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
