gears, gears, gears
  • Thread starter Thread starter 302RWP
  • Start date Start date Feb 21, 2004
302RWP
100
Northern California
Feb 21, 2004
  • Feb 21, 2004
can someone help explain what the gears mean? ex. when someone says the have 4.11 gears what does it mean? what is better higher or lower? please help me out with this
ratio411
3,870
73
109
Pensacola FL
Feb 21, 2004
  • Feb 21, 2004
A 'lower gear' actually has a higher number.
Lower gears give more leverage and get your RPMs up quick.
A lower gear is always good for accelleration and response. It will make you faster, assuming traction.
The drawbacks are higher RPM highway operation and reduced fuel economy.
Higher gears, also called highway gears by some, are good for high speed cruising and mileage. The engine RPMs come up slowly and therefore throttle response and accelleration are 'dampend'.
Most classic Fords came with highway gears ranging from 2.70ish to 3.00.
Middle of the road gears are 3.25 to around 3.50
Anything numerically higher are good 'stump pulling' low gears.
Ford went as low as 4.30 gears in a select few cars. Anything beyond that and you have gone too low unless your car is single purpose and you have put alot of thought into your gearing.
The 4.11 is a very good gear IMO, but as an example of going overboard on low gearing... I have put 4.11s in a car that was almost pure stock. The thought was making the car faster with gears and not too many engine mods. It didn't work... An engine that can't use fast revs or make power at higher RPMs cannot efficiently use low gears. Therefore, the car drove like a dumptruck rather than faster. It couldn't make power at any speed because the gears ran the revs up too fast.
I hope this helps.
Dave
brianj5600
1,964
Middle TN
Feb 22, 2004
  • Feb 22, 2004
By faster he means quicker.
HistoricMustang
2,359
Confederate States of America
Feb 22, 2004
  • Feb 22, 2004
Great discription!
HistoricMustang
www.historicmustang.com
rbohm
6,698
550
204
tucson,az
Feb 22, 2004
  • Feb 22, 2004
I hope this helps.
Dave
nice job dave
mfp4073
387
Hells Ditch, FL
Feb 22, 2004
  • Feb 22, 2004
damn...that was good!
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
