Gears really tight?
  • Thread starter Thread starter Lynx331
  • Start date Start date Sep 12, 2004
L
Lynx331
308
Chicago IL
Sep 12, 2004
  • Sep 12, 2004
My gears are really tight, if im brakeing to a stop sign it takes alot of effort to get the car into 1st for example. Would a after market shifter clear it up?
T
Trefty
117
  • Sep 12, 2004
Yea, I'm having the same problem, although it's when shifting into reverse. I would assume that an aftermarket shifter, or even a used shifter that is in better shape would fix the problem.
maverick0716
3,924
Chilliwack, BC, Canada
Sep 12, 2004
  • Sep 12, 2004
It's your transmission thats the problem, not the shifter. An aftermarket transmission will not cure it.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 12, 2004
  • Sep 12, 2004
What is happening is that the clutch isn't completly dissengauging. This is usually a fault in the stock cable and quadrant system. Your cable is probally stretched more than the quadrant can adjust. More than not, a shifter won't fix the problem, neither will a new tranny.
I would look into one of the many aftermarket quadrant/FWA/cable kits, that should fix the problem.
HISSIN50
34
129
Sep 12, 2004
  • Sep 12, 2004
this was my first thought too - certainly amongst the first things that needs to be checked (it is relatively easy to check).
or it would be a clutch issue itself (worn out disc, etc).
but i think we might be askew here. in reading your post again, you say it is hard to downshift into first while rolling. ummmm, that is not the best thing in the world to do. while first does have a synchro, shifting down to first is not a great thing - if you need to do it, be sure to rev match to help out your synchros/blockers (if you are driving over 5 mph and try to jamb it into 1st at 1K rpm, it aint gonna like it).
for reverse grinding, put it in a forward gear first, then reverse. this slows the cluster down so you dont grind the straight cut reverse gears.
good luck.
L
Lynx331
308
Chicago IL
Sep 12, 2004
  • Sep 12, 2004
good luck.
Sotrry i didn't clarify that enough, i dont downshift into first going to the stop sign i put it into first with my foot still on the clutch getting ready to take off from the stop sign
Stang8URMPRT
1,100
Daytona Beach, FL
Sep 12, 2004
  • Sep 12, 2004
Another possible problem other then a worn cable/quad is a blocker ring or syncro. When these wear, they do not allow engaugment of 1st from a dead stop. In my years with T-5s (6 of them) this has happened in 4. Eventually it will start popping out of first and grinding putting into first from a roll.
Nick
PhLoBuS
473
Beverly, MA
Sep 12, 2004
  • Sep 12, 2004
is it happening to autos? anyone??
HISSIN50
34
129
Sep 13, 2004
  • Sep 13, 2004
huh? are you asking if this can happen with automatics?
A
alex95621
32
#10
  • Sep 13, 2004
  • #10
asdf
i drive an automatic, and last week after i blew the output shaft seal, my car would rev up when i went to take off and it would take a second to engage and start moving, but after i fixed the seal and everythin and filled up the tranny fluid it was fine
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:17 AM
keel
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
