Gears
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date Dec 28, 2006
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Dec 28, 2006
  • Dec 28, 2006
After a clutch install, I noticed the following....
1. The clutch pedal vibrates, to the point you can hear it and it shakes your foot.
2. The shifter is very tight. You have to put a lot of force into changing gears, and even worse when you try to put it in reverse. Before the install, I was able to shift from gear to gear with ease.
Any idea's on what it is?
HISSIN50
34
129
Dec 28, 2006
  • Dec 28, 2006
THe pedal always vibrates?
How is the clutch cable adjustment? It sounds like you might have too much slack in the cable (and are not disengaging the clutch all the way).
Good luck.
Turkey Sammich
Jul 12, 2006
154
Dec 28, 2006
  • Dec 28, 2006
Good luck.
It vibrates from the time you start it, until you shut the car off. Reguardless of having your foot on it or not.
Could be to much slack. I'll have to find out tomorrow and re-adjust it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2006
  • Dec 29, 2006
I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. If I shift only when the pedal hits the floor, there are several milliseconds that the clutch disk is not being driven by the engine. In theory, this lets the disk speed equalize and makes less work for the synchronizers – keep in mind that this is a theory, but it seems reasonable. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
HISSIN50
34
129
Dec 29, 2006
  • Dec 29, 2006
Very good advice from JR. I adjust mine approx the same way.
If it vibrates at all RPM and all times, are you sure the flywheel and clutch assembly went back on properly?
Good luck.
Turkey Sammich
Jul 12, 2006
154
Dec 29, 2006
  • Dec 29, 2006
Good luck.
The clutch cable was loose. It's adjusted and feels great now.
The short shifter was bolted in to tightly, but it's just a bit looser now and shifts ALOT better. Thanks for all the advise.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
