Just had a handful of random questions about ensuring you buy the right cylinder head for a given engine.
1) I noticed Trick Flow heads differentiate between 1.46" and 1.47" spring O.D., and also have an option for both o-ringed and non o-ringed heads? Whats the advantage or application for each?
2) If you purchase a set of heads with 7/16" head bolt holes, and need 1/2" bolt holes (ie buy a set of heads designed for a 302 and try to use them on a 351w), is it advisable to have the hole enlarged? Or does this compromise the head at all?
I know I had a few other questions but they're escaping me at the moment. Thanks!
Those SRP's have .003" deck clearance
