  • SN95 4.6L Mustang Tech
Get a tune?
  • Thread starter Thread starter Mr GT 02
  • Start date Start date Oct 11, 2004
Mr GT 02
548
Peabody, MA
Oct 11, 2004
  • Oct 11, 2004
I have seen people say to get a tune for those people that are getting a new Throttle body and plenum (accufab). My question is.....How do you get a tune? what are you tuning? and for what reason is a tune nescessary?
Could you do the tune yourself? what do u use for tuning? help...
Mr GT 02
548
Peabody, MA
Oct 11, 2004
  • Oct 11, 2004
w00t
334
Arlington TX
Oct 11, 2004
  • Oct 11, 2004
stang976
853
Westchester, NY
Oct 11, 2004
  • Oct 11, 2004
i wouldnt get a tune after such basic mods unless you are having idle isuues directly after the install.... 'getting a tune' involves adjusting and monitoring things such as fuel pressure, and your air to fuel ration throughout the RPM range.. other things like shift points, speedo calibration, etc.. can also be done.. i highly recommend a professional dyno tune over doing it yourself with a handheld or wideband.... but to answer your question i think you should do some more mods b4 spending $500 on a good tune
kah9911
102
Downingtown, PA
Oct 11, 2004
  • Oct 11, 2004
I had no issues after I installed the Accufab stuff. I reset the computer but other then that she ran perfect right away. You would benefit from a tune even if your car is bone stock but I would wait until you have some more mods or need to fix your speedo or shut off your rear o2's.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
