get code without scanner on 99GT?
there are codes that will be present on the odometer. theres a procedure where you hold down the trip reset button for a number of seconds. however, those are not the ODB2 codes. part of OBD2 requieres that all codes can be pulled with a OBD2 certified scan tool. this is the same for every manufacturer.
side note: 1000 posts :spot: :spot: :banana: :banana:
