Getting Frustrated
  • Thread starter Thread starter idaho_88
  • Start date Start date Dec 6, 2005
I
idaho_88
15
Boise,Idaho
Dec 6, 2005
  • Dec 6, 2005
I'm getting frustrated... My 88 GT is a 5-speed and has a weird problem. Whenever I am coming to a stop and get ready to shift from 2nd to 1st, and brake, my car dies. It doesn't die every time, just occasionally. I just got it back from the shop, which told me my brake booster was bad. They changed it and also bumped the timing up a little. I had a charging system check a couple weeks ago and everything was good. What else could be wrong? I just bought this and just want it to run smoothly. Thanks for any help.
HISSIN50
34
129
Dec 6, 2005
  • Dec 6, 2005
Check the IAC. Various sources show that the no-load warm idle adjustment for SD cars requires IAC to function and flow properly (different than MAF).
How is the cold idle and loaded idle? Is your VSS hooked up?
Absent other ancillary info, I would clean the IAC for starters.
Good luck.
HISSIN50
34
129
Dec 6, 2005
  • Dec 6, 2005
And if you choose to clean the IAC, here is some info about cleaning it up.
Good luck.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 6, 2005
  • Dec 6, 2005
Not that it apply's to you but and don't laugh my dads 86 diesel jetta would't stop the engine when the key turned off. but when you touched the brakes when the key was off it would kill the engine. turns out a ground in the rear brake light assemble was loose and it was causing the problems. In your case i would say IAC. You can remove it and clean it up. Perhaps when you are comming off the gas the computer is not getting the Throttle postion correctly. You can check to make sure you have about .96 volts on that sensor. no more the 1.00 volts and no less then .8 i believe.
I
idaho_88
15
Boise,Idaho
Dec 6, 2005
  • Dec 6, 2005
Thanks Hissin
Thank you for the quick response. I will try out the IAC tommorrow, as far as cleaning it. Should I go back and get my money back for a new brake booster? The article you recommended is awesome. I let you know what happens.
I
idaho_88
15
Boise,Idaho
Dec 6, 2005
  • Dec 6, 2005
Thanks 86 blue.
Your dads situation sounded weird. Anyway thanks for the info. I will check it out and repost.
HISSIN50
34
129
Dec 6, 2005
  • Dec 6, 2005
I cant say on the booster. If the old one was really leaking, it needed replacement for safety's sake. Normally the brake pedal will get hard or feel like you really have to push hard to slow the car (like how it feels if you coast to a stop with the car off).
If you are still SD (the assumption for now), the vacuum signal is critical for the engine management (one reason to replace a leaky booster). So before if there was a leak, the computer thinks you have the throttle pressed down when you dont (while at idle). And ironically, a vac leak would have raised your idle up, and allowed the idle to hang high upon coming off the throttle. So this might have masked the underlying issue which you are now dealing with.
If you want to check your vacuum, a stockish motor should read about 18-20" hg at idle.
We should also have noted that retrieving the trouble codes is always a good place to start. A SD stang does not have a functional CEL (even though there is an outline for one). A very wise man in here named Jrichker very often posts links and info on retrieving the trouble codes.
Good luck bud.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
