Getting new goodies, what other parts should I get?
OneStiffGT
87
Canada
First of all, I ordered the Ford Racing Aluminum Drive Shaft, I am going to be installing my SPEC Stage 3 clutch, and my aluminum flywheel as well, so I got new clutch forks, t/o bearing, pivot shaft and pilot bearing. I also ordered new u joints with the driveshaft, the clutch pack rebuild kit. Do I need a new yoke, does it come with the driveshaft? Should I order aftermarket transmission mounts since the tranny will be dropped to install these?
I am also ordering the tubular k member and the tubular a arms, should I get some aftermarket motor mounts while I am at it? I am also getting my long tubes installed w/ new x pipe and mid pipes while the k member is out, as well as the aftermarket steering shaft, what other parts should I be getting while the k member is out? (I am offcourse getting the MM Coilovers as well, I just gotta take my sturts off the car and send it to them so they can put the groove on the struts?)
Thanks
