Glowing red headers...
  • Thread starter Thread starter 358stroker
  • Start date Start date May 1, 2006
1 of 2 Next Last
358stroker
62
Austin, TX
May 1, 2006
  • May 1, 2006
I changed my intake this weekend and when I put it back together and fired her up I noticed my headers were glowing red within 2 minutes or so.
My electric fan turned on within 60 seconds or so, so the car is obviously getting hot very very quickly.
any ideas on WTF is going on???
86mustang5.oh
125
battle creek mi.
May 1, 2006
  • May 1, 2006
is it a aftermarket intake? maybe its too rich.....friends s-10 did that and burnt a few valves fuqing chevy
86mustang5.oh
125
battle creek mi.
May 1, 2006
  • May 1, 2006
i mean lean by the way not rich too much air
358stroker
62
Austin, TX
May 1, 2006
  • May 1, 2006
Yes it's a Trick FLow Track Heat. I had an old GT-40 before.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
May 1, 2006
  • May 1, 2006
wow, just changing intakes should not cause that problem...
did someone stick some potatoes in ur exhaust for an extreme case of backpressure??? lol jk
G
GREYFOX4INCH
190
western MA
May 1, 2006
  • May 1, 2006
my old monte carlo did that when the cat went bad and clogged up, i guess to much back pressure can cause that. it may not apply to you but i thought i would mention it
double check all your fuel stuff.??
edit: someone above mentioned a lean mixture, maybe you have an intake leak and your sucking in air that is not being accounted for
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 1, 2006
  • May 1, 2006
how is the timing? maybe its way too retarded and its firing as the exhaust valve is opening. maybe not, im just throwing out some suggestions
358stroker
62
Austin, TX
May 1, 2006
  • May 1, 2006
I don't have cats, so that couldn't be the issue.
I suppose the timing could be off, but the car starts and idles. Although the idle is very high around 1200. Never was high before. I swear I put the distrubutor back in the way it came out so I'm not sure how the timing could be that far off...
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
May 1, 2006
  • May 1, 2006
my guess would be a bad vacuum leak than, if its idling that high. probably wouldnt hurt to check the timing either.
358stroker
62
Austin, TX
May 1, 2006
#10
  • May 1, 2006
  • #10
To check for a vaccum leak what's the best type of spray to use? Carb spray, Brake cleaner etc??
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
May 1, 2006
#11
  • May 1, 2006
  • #11
carb spray or starter fluid. or you can take a spray bottle with water in it...it does the exact opposite and will bog the motor down instead of revving it up. id prefer the water method since you dont want to spray ether or whatever on a glowing red hot header.
358stroker
62
Austin, TX
May 1, 2006
#12
  • May 1, 2006
  • #12
I can try it, I just don't want to start it for too long as those headers glowing couldn't be a good thing.
dastang2
2,020
tx
May 1, 2006
#13
  • May 1, 2006
  • #13
you might as well not even try that. you know there is a leak somewhere. just make sure all the bolts are tightened and in the right order. replace gaskets if needed.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 2, 2006
#14
  • May 2, 2006
  • #14
you said it idles at 1200 that's a good sign of running lean. Also every time you take your dizzy out you should hook the timing light up at least I do just to make sure but that dosn't sound like it's the problem.
358stroker
62
Austin, TX
May 2, 2006
#15
  • May 2, 2006
  • #15
Roland69, what is the "dizzy", do you mean distributor?
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
May 2, 2006
#16
  • May 2, 2006
  • #16
yeah, he means the distributor
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
May 2, 2006
#17
  • May 2, 2006
  • #17
Run a bead of clear rtv around the intake->head mating surface down around the intake->block surface and seal the intake to the motor. Dont remove the intake, just run it along the outside along the 2 surfaces. Then see what happens. This usually fixes it for me.
Also double check your oil. If the intake is leaking to atmosphere then it might not be properly seated and you may have coolant dripping into the lifter valley as well.
If it makes you feel better, took me 3 tries to get my edelbrock intake to seal up against my gt-40p irons. Finally I ran the RTV bead and no problems since.
358stroker
62
Austin, TX
May 2, 2006
#18
  • May 2, 2006
  • #18
I guess I don't understand how a vacuum leak could cause my headers to glow...
crazypete
Oct 22, 2004
930
Arlington, MA
May 2, 2006
#19
  • May 2, 2006
  • #19
Your high idle indicates that the intake is leaking.
This causes the engine to run very lean...combined with the higher idle, it pumps out a lot of heat.
mike50sa
26
san antonio, texas
May 2, 2006
#20
  • May 2, 2006
  • #20
Sounds like the intake gasket is blocking the water passage, keeping the coolant from flowing through the intake and making it hot. Double check it. Vacuum leaks will make it run like crap, but won't cause it to get that hot, that quick.
Good luck!:SNSign:
1 of 2 Next Last
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
