Glowing red headers...
  • Thread starter Thread starter 358stroker
  • Start date Start date May 1, 2006
First Prev 2 of 2
89white50
440
central MA
May 2, 2006
#21
  • May 2, 2006
  • #21
glowing headers def. means your running lean, i like the thought crazypete has about intake leaking. obviously your not running real rich cuz that would not happen and you would be able to smell the fuel...i would reseat the intake and see if that help, if not then its a fuel problem...
dastang2
2,020
tx
May 2, 2006
#22
  • May 2, 2006
  • #22
mike50sa said:
Sounds like the intake gasket is blocking the water passage, keeping the coolant from flowing through the intake and making it hot. Double check it. Vacuum leaks will make it run like crap, but won't cause it to get that hot, that quick.
Good luck!:SNSign:
this is totally wrong. sure it will. i know for sure i have an intake leak because i can hear it and within 1 minute they were setting the plug wires on fire and glowing. lean mixtures cause hotter temps. rich mixtures cause cooler because the fuel cools the chambers.
358stroker
62
Austin, TX
May 2, 2006
#23
  • May 2, 2006
  • #23
<<<<UPDATE>>>>
I fixed the problem. Apparently I suffer from a disorder called "can't do 2 things at once"
When I was on the phone and installing my thermostat, I put it in backwards.
So there was Zero water getting to the heads thus not cooling my heads and making them glo red.
Lesson learned NEVER, NEVER, NEVER do 2 things at once while working my car, my brain can only do so much at one time....
Oh yeah, and the high idle was my throttle cable not positioned correctly.
thanks for all your input...
mike50sa
26
san antonio, texas
May 2, 2006
#24
  • May 2, 2006
  • #24
Glad you found it! It always feels good to nail it.
dastang2
2,020
tx
May 2, 2006
#25
  • May 2, 2006
  • #25
sure does heat up fast i guess i retract my previous statement
dvs bullet
326
Ontario, Canada
May 2, 2006
#26
  • May 2, 2006
  • #26
that happen to me, I didn't hook up some vac line properly, check them over
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 2, 2006
#27
  • May 2, 2006
  • #27
wow hope you didn't wreck anything. last time i seen headers glow like that it was because timing was way retarded. but it is always nice to have another reason for that to happen.
358stroker
62
Austin, TX
May 2, 2006
#28
  • May 2, 2006
  • #28
It heated up way faster than I thought it would, they were glowing within 2 minutes.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 3, 2006
#29
  • May 3, 2006
  • #29
thats scarey. hopefully the exhaust valves are still ok. that is a lot of heat going through them.
First Prev 2 of 2
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
