Going Carb
  • Thread starter Thread starter BiteNGo92
  • Start date Start date Feb 25, 2010
BiteNGo92
Mississippi Gulf Coast
Feb 25, 2010
  • Feb 25, 2010
So here it is...Im going to carb, against the wishes of my fuel injected peers. I know about the fuel pump and other fun stuff, but i need info on alternator and wiring the ignition. I have accel 300 but if the msd is a little less of a headache let me know. Anything is helpful and appreciated.
rd
3,316
63
109
Ocean Springs MS
Feb 25, 2010
  • Feb 25, 2010
Do a search for this, it has been covered in details. The common way to do this is with a Duraspark distributor, which means getting one for a roller cam, adding the fuel pump eccentric to the cam, getting a timing cover for the mech fuel pump, (or use and electric pump), a suitable tank pickup. Also need the intake, throttle cable.
The alt wiring should not change. The ignition needs power when the key is in start and run. Not familiar with the Accel unit, but I have an MSD Digital 6/Duraspark dist in the 82. I think I have the original Duraspark box power wire (not the coil wire) turning it on and off. Really not much to it. Best to consult the manufacturers instructions.
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • dan50
  • Jul 18, 2026
dan50
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
