Going to do a tune up have a few??'s
dont have to take the fuel rail off. just need a 7mm for the coils and a extra deep 5/8 spark plug socket for the plugs.
the stock motorcraft ones are good, but getting the Autolite APP764 will get you the same exact plug. motorcraft plgus are made by autolite.
how many miles are on the car? you should also:
-change oil and filter
-change/clean air filter
-change fuel filter
-change trans fluid and filter
-chagne coolant
-change diff fluid
-chagne p/s fluid
-inspect brakes(might want a shop to do that)
-flush brake fluid
-rotate tires
Not to hijack this thread.....but is a p/s fluid, brake fluid, and diff fluid change really necessary, and if so, how many miles? I can see doing an auto tranny fluid and coolant.
I've never heard of flushing brake and ps fluid unless you had to empty the system and bleed it for some reason.
you flush the p/s fluid to help keep it from making the terrible ford noise. also you will be amazed at how the car feels with Mobil 1 ATF for p/s fluid.
for brakes, you always should flush the brake fluid anytime you do pads. i flush mine a few times a year, using Valvoline synthetic DOT3/4. i flush it before i go to a track event, then at the track i try to flush the calipers after every other hotlap session, then i do a full flush when i get home. having speed bleeders really helps in that i can have all the fluid flushed in about 15 minutes.
