I've done decided the car is getting the gas this winter, probably around christmas time. Not sure whether I should run wet or dry, what would be best? The car has 24lb injectors with a 190 fuel pump for fuel mods, then a 10:1 comp 306 with h/c/i. I plan to start out with a 50 shot and would like 150 on tap. My goal is to push roll cage territory this spring with the help of SFC's and tires. What would be the best kit for the money? I know I'll need a kit, bottle heater, purge, some gauges, wot switch, and probably a window switch as well. Will that about cover it, or will the fuel system need some more work?
As for timing, what would be best? Right now the car sits at 20* timing. Drop it back to stock and bump it a couple degrees at a time with the bottle?
Thanks.
Thanks.
