it should make 600 rwhp but since its my car it'll make around 400
i have an 8 rib kit ready to go on it.
fuel system should hold out for a little power. i have an 03 cobra tank with twin GT supercar pumps with a modded FPDM. i'm not sure where it will max out at but i think it will be close to its limits.
. I was running around 12.5PSI but had to back it down to 12 and its still going lean up top. I have the PPRV inline still and stock wiring...so if you remove those two problems it should support 650RWHP or so.
Now you are building a built block, I hate being poor
I have the exact same setup and they are done @ 12PSI. I was running around 12.5PSI but had to back it down to 12 and its still going lean up top. I have the PPRV inline still and stock wiring...so if you remove those two problems it should support 650RWHP or so.
I would HIGHLY recommend you do that if you have not already.
at least i have some time to get those two problems taken care of before the engine goes in. i have a 4 gauge wire running to the trunk already for an small amp i have back there. i can just split an 8 gauge wire off that to the FPDM. i guess i might as well run it to the pumps as well if i'm dropping the tank to delete the PPRV.
