  • SN95 4.6L Mustang Tech
Good deal?
  • Thread starter Thread starter VividDreams
  • Start date Start date May 27, 2005
V
VividDreams
200
Lebanon County, PA
May 27, 2005
  • May 27, 2005
I know a guy that has an 85 GT vert with a 351W, some work, and nitrous. he complains that he cant hook with the 3.73's that he has in it an he is considering going to 3.27's, which i conveniently have in my car. he says they only have about 5k miles on them. would i be getting a fair deal if i swapped him?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 27, 2005
  • May 27, 2005
An '85 GT has a 7.5" rear end, you're '02 has an 8.8" rear end. Sorry Dude, unless he's swapped it out for a later model rear end....no dice.
Now....assuming he did swap it out, tell him to take you for a ride and make sure it doesn't howl or whine while cruising. If they sound good and are the right size rear end, you’re good to go.
01SN8K
135
  • May 27, 2005
there are a few things to consider. one is who or where is the gear install gonna be done. rear ends are a pain if not done right the first time. if the gears are not that old there will be little wear on the ring gear. if you can ride in the car like suggested. the car should be taken on an easy ride so you can listen for gear whine. listen for it while accelerating coasting or getting into and out of the gas at cruising speeds. if you can hear the gears then they were shimmed wrong and i would steer clear.
V
VividDreams
200
Lebanon County, PA
May 28, 2005
  • May 28, 2005
yeah, the rearend was swapped for an 8.8
i will say something to him about taking a ride though.
a friend of mine went to WyoTech and has doent a rearend or two. he now works at a Honda dealership. his lead tech at work has a lift in his personal garage, so they will be doing it
lazerred02
190
FT Stewart, GA
May 28, 2005
  • May 28, 2005
Gears are not that pricey, if I was you I would just buy a set from FRPP and be done with it.
L
Lav_2002GT
20
Leesburg, Georgia
May 28, 2005
  • May 28, 2005
Brand new gears, if not installed properly, can whine.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 29, 2005
  • May 29, 2005
Point?
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
D
What's it Worth? 2006 Mustang GT Convertable
  • doc0075579
  • Mar 2, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 2, 2026
doc0075579
D
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
  • Gulftown980x
  • Jul 29, 2026
squeak93
